- 5 Sep 2011
- Surrey
What does Having system memory and a decent SSD do??? If you run out of VRAM that won't do anything at all
Nope, SLI reports the actual VRAM used and unlike AMD, doesn't need halving.
Clocks were stock SLI Titans (837Mhz) and CPU 3930K at 4.625Ghz.
This thread got more replies in 1 hour even though its the same old asked 100x Q and some peeps asking for help are lucky to get a reply in some threads lol.
OP could have used Search.
does this mean that if you have 2 x 2gb cards in sli you then have 4gb vram while if you use 2 cards in crossfire then you only get the vram from one card in use
at 1080 there are a handful of games that use over 2gb skyrim,bf4 can , titanfall definitely does.
so yes 2gb is okay for 90 percent of games still but it will be pushed this year with bigger games.
1 is not rly enough
2 is fine for 1920x1080
3 is fine for 2560x1440
eyefinity fits in there somewhere but not sure where
And BF4 is pretty intensive too. Thing is though it will buffer the current frame and however many frames ahead, so with a titan although it says you're USING say over 3gb at 1440p you're actually not, with caching it's using as much as the game thinks it needs to and works with what's available. BF4 has some massive maps, so if it's buffering a further 10 frames for example, it's going to cache a lot of VRAM along with any other info the GPU needs. If you have 3gb VRAM, it won't cache as much.
At least that is the most obvious explanation. Which is why all these VRAM readouts prove nothing.
Thats most likely the reason why my VRAM useage shows 3.95Gb in single player 95% of the time.
This time next year 2Gb will be no where near enough for 1080p
Im trying to do some research for my next purchase and it looks like 2gb vram is no longer really enough. The cards I were looking at was the gtx 770 which mainly comes with 2gb vram and the occasional, highly priced 4gb ram. On closer reading it appears that the 770s dont have enough grunt to make use of the 4gb anyways.
Basically if the general consensus is 2gb is no longer enough why did nvidia release mid-high end cards with onky 2gb ram?
im trying to wisely choose my card that will hopefully last as long as possible but stuck now as what to do
any help or advice in the right direction really appreciatec
The answer is simple.
If you play games with **** poor IQ settings then 2Gb will be fine.
If you play games with IQ settings turned on then 2Gb is not enough.
Although why anyone would build a gaming PC and not have the IQ settings turned on is beyond me, may as well buy a PS4.
