Yes but it's not in the same league as something like an M27Q, GL850 or MAG274QRF-QD.
You’re right I had forgotten that this is to be a gaming monitor.
Bump, have the same dilemma atm!
Choosing between two 144p screens, 27" or 32" (both IPS).
Spent several tortuous moments with the tape measure, against my existing 1080p 23". I can't help but feel the 32" would be absolutely massive, with lots of head turning.
The only thing I'm worried about is the smaller pixels on the 27", and having to set screen scaling above 1:1 which would be too small for text. In theory smaller pixels are always better but still in 2021 not everything supports scaling properly. At 32" 144op the pixels are the same size as my existing screen.
I've got one and I compared it to my oled and it doesn't seem that different, although I tend to play fps on the TV and rts on the monitor. What's a good way to measure them as I have them side by side. I do agree that there's very little in it and while you sometimes get what you pay for, I'm not sure a monitor that costs almost as much as an oled is really worth it.Yes but it's not in the same league as something like an M27Q, GL850 or MAG274QRF-QD.
For one, the input response time of the iiyama is known to be ~20ms (vs ~3ms on those above). As for the pixel response times, there are no reviews from people like RTINGS, and the most I've been able to find out is that the panel is made by BOE, a large Chinese panel manufacturer with their own IPS-type tech called ADS.
If you want something with proven (and reviewed/measured) pixel response times in the sub 6ms region, you're looking at £800+ in the 3440x1440p space. From the likes of Dell, LG, Acer.
Overdrive implementation is one of the most important factors in a gaming screen, and until the iiyama GB3461 is reviewed by someone like RTINGS (etc), I will continue to very much doubt it's on par with someone like LG Display.
Ultimately, you get what you pay for, with almost no exceptions.
So I stand by my comment - if you want a fast IPS, and you're moving from 27" 16:9 to UW 34", you need to dig a lot deeper in your pockets, unless you want to sacrifice spec.
I'm a little surprised at how some use that 48" OLED as a monitor.
Well if you can't see a difference side-by-side I'd just be happy and not bother with the measuringI've got one and I compared it to my oled and it doesn't seem that different, although I tend to play fps on the TV and rts on the monitor. What's a good way to measure them as I have them side by side. I do agree that there's very little in it and while you sometimes get what you pay for, I'm not sure a monitor that costs almost as much as an oled is really worth it.
All I did was use my phone with a fast shutter speed. I do wonder how much of this is mountain out of a molehill, average reaction time is 300ms, is an extra 20-30 going to make that much difference, some people online have worse ping than that.Well if you can't see a difference side-by-side I'd just be happy and not bother with the measuring
I think the review sites use high-speed cameras to measure the pixel transitions. I don't have access to anything like that.
I've very recently moved from 27" 1440p to a 32" 1440p screen and have been very pleased with the experience.
You're making me want to give it a trySo you think a 48inch is big!, I personally use my 55inch OLED as a monitor but I sit far back and enjoy the IQ on a OLED compare to a close up LCD monitor, bigger is always better than small when gaming on![]()
You can also go a lot bigger than that there's some insane 55" plus TV/monitor ones out there that are equally insane in price, but to have oneHave used 32 inch tv as monitor for over 15 years. First was 32inch 720p then 1080p. Now im on the hunt for 4k 32incher.
There is a article about using a 40inch tv as monitor and works out very well.
