Spoffle you are going way off course, the only thing people care about is if the higher % ment it got better OC and it doesnt so everything else is just pointless.
I'm not going way off course. You don't understand the topic, that's your fault, not mine.
Higher percentage has never been suggested as an indicator that it's a "better" overclocker, it's an indication on how well that chip will behave under certain circumstances.
Yes you are because its all pointless the Asic doesnt tell how the chip behaves at all because its broken :\
Your trying to explain it when it doesnt make sense at all!
How can it make sense if a chip with 50% can beat a chip with 85%!
Asic score is all about overclocking and if it doesnt work out like it should its pointless.
Ofc higher % has been suggested better OC thats what the thread is about :\...................
LOL yes i do. OFC the bigger number is meant to indicate this, thats the full point of it otherwise its pointless.
We are going around in circles here, if the score is not to show how well it should overclock then wtf is it for?
Because if not then its pointless like it already is.
It has a relationship, what you've suggested isn't the relationship.
The relationship percentage is supposed to indicate how well it will clock depending on the situation.
Ie, how it's cooled.
) inbuilt to the gcn architecture was in part to enable more gpus were available instead of throwing out a lot more.
my card refues to go above 1200 core and remain stable unless i give it all of the voltages.I agree with what its supposed to do but it doesnt do it.
Its not crap mate, if people can get better clocks with lower volts on a lower scored card then it means its CRAP, dont blame me for it not working as it supposed to, it all sounds fine and dandy but it doesnt add up does it :\
And the relationship crap is not that at all, its saying if u have a crap score then watercool it as it cant cope on air :\ but then we see some watercooled cards being beaten by air cooled cards, i dunno how you cant grasp this because its not complicated.
Hamish take this as friendly advice(or not)-it's implied that way, you are telling some they are wrong when you don't know, your guessing(I think) sometimes then jumping into a full tirade of 'your wrong' when it differs from your own view.
That's all very well but not when you don't know what your talking about yourself.![]()
Yeah i get you but it doesnt mean u need to put them underwater because people on air with low asic still get good OCs.
Its a double headed coin tbh, there must be very little in it, so its nothing worth worrying about.
I dont insist high is right :\ ive been saying that from the start low can beat high lol? What you been reading?
Best way to test this is find some peeps with low asic and high and do a test, because what your saying should be right but its still not the case 9/10 times.
