Will depend on the voltage you need for 4.5ghz. Mine needs 1.300 in bios, llc on high. Temps range from 64c on the lowest core to 74c on the highest at 100% load. Cooler is an alpenfohn k2 with dual akasa piranha fans. Temps in game only hit over 60c max.Which cooler you using atm?
I'm only using Hyper 212 Evo and after 30 mins of Prime95 the max temp it reached was 61c which I thought was pretty ok after half an hour of 100% load, which I can't imagine I'm ever going to do in normal circumstances.
Wondering if I should push to around 4.5? Idk if it would be worth it.
Cheers man,
I've been running at 4.5ghz and Prime95 blend for 1hr 30mins now with no errors, everything seems to be passing and temps are sitting around 55-60, peak at 66 but never go passed it.
If I make it to 2hrs with everything still being fine, can I call it a pass? Getting kinda bored not being able to play! lol
