The self awareness is weak with this oneYes, people are stupid. Tell me something new.
BTW. Good luck telling your boss you can't go to work because you couldn't be arsed buying some fuel out of your "normal routine".
But the people buying fuel now, won't be buying fuel next week, so it will even out.Just imagine the fuel tax revenue the gov will rake in…..
Does E10 have a reduced MPG? Heard that’s about 5% less so if your tank did 400, it will do 392.
I wonder if a closed garage would have a problem with me lifting all the hoses and collecting the dribbles in the bike i get 20miles/l+ out of it so that would do me
Tesco broughton is closed out of fuelDon't they all get padlocked down when a petrol station is shut ?
Shell station in Ellesmere Port didn't have any queues when I drove past just after lunch and only 2 of 6 pumps were being used. Is this panic a silly southerners thing again ?
Tbh if Boris went on tv and said there was a shortage of underwear and not to panic buy it the sheeple would dash to the shops.
I appreciate there are underlying issues that need resolving but the very fact Boris told people not to panic buy caused this current issue.
Lolwut?Yes. Exactly. It's it's not "sheeple". It's perfectly rational to panic buy in a situation like this. Boris really is idiotic sometimes. Proper, real, bone fide idiotic. This is a classic example.
Lolwut?
Could the fuel pumps be programmed that a max amount (determined by manager) could be dispensed? So for example, 20 litres. Drivers are not allowed to go around again to get another 20 litres.
Only allow drivers with less than 25% of tank and key workers - need to provide proof such as ID card, discount card, pay slip etc through. Everyone else should be turned away.
Yeah good luck running your fuel station like that.Only allow drivers with less than 25% of tank and key workers - need to provide proof such as ID card, discount card, pay slip etc through. Everyone else should be turned away.
