I bought this one, if you're interested. Seems pretty solidly built, it comes with a sturdy bracket that you mount to the ceiling (make sure it's solidly mounted ideally to a joist) and wire up, then you lift the fan assembly up and slide it into the bracket so it hangs from it on a rubber gimbal. I was able to install it myself in probably under an hour (although that doesn't include the time I spent trying to figure out the wiring from the old light and then giving myself a shock anyway).
So far it's been rock solid, well balanced so no vibration or noise. Beware it uses a remote to operate, but batteries aren't included.
https://www.diy.com/departments/col...hrome-effect-ceiling-fan-light/1876518_BQ.prd
