It’s such a shame the external shutters look so industrial/commercial. I’d love some on our house, just think it’d look very “afterthought” to retrofit. Deep recesses windows like in this article look perfect for it!Yeah, I think it only makes a difference of a degree of two. Apparently it still lets in 90% of the heat. Need external blinds or other form of shade to really make a difference.
Article I was reading on the subject: https://www.heatspaceandlight.com/how-design-build-home-uk-cool-summer-case-study/
Tape foil to the windows. Thank me laterIt’s such a shame the external shutters look so industrial/commercial. I’d love some on our house, just think it’d look very “afterthought” to retrofit. Deep recesses windows like in this article look perfect for it!
That’s fine but you need to do it to the outside which often isn’t practical for upstairs windows. You risk popping seals if you do it internally.Tape foil to the windows. Thank me later
Mines all taped inside. **** the seals.That’s fine but you need to do it to the outside which often isn’t practical for upstairs windows. You risk popping seals if you do it internally.
Taped inside to the window frameThat’s fine but you need to do it to the outside which often isn’t practical for upstairs windows. You risk popping seals if you do it internally.
Football was canceledBit warm to be doing running but I managed it
Which risks blowing the seals when it heats up the two panes of glass and the gap between. Have to block from the outside for it to mean anything.Taped inside to the window frame
It’s not caused those issues. I’ve never heard of this and have done this in far hotter countries. It’s kept my house down below 28C all day.Which risks blowing the seals when it heats up the two panes of glass and the gap between. Have to block from the outside for it to mean anything.
Probably a sensible choice, my run is only 30 minutes so not too badFootball was canceled
Yeah, had to turn down the aircon earlier. Was getting a little chilly. Popped outside to put some washing out... wow, did you guys realise.. it's hot out there!?At work I have air conditioning in the office and a little usb desk fan. I had to turn the desk fan off as I was a bit nippy.
