- 18 Oct 2002
- Liverpool - UK.
jake000 said:Nice looking car
How fast is your corsa out of interest?
Erm, 0-60 in around 7 secs and a 15 sec quarter mile or so.
Randell Floyd said:Welcome to the club.
Mine's red as well, but I gave into temptation and upgraded a few things!
240bhp & 250lb/ft now( and I genuinely say I wouldn't want any more from a FWD car! )
Liverpool-Lad said:Just wondered, are you in the NW? I wouldnt mind a nose at the car and mods you have done!
130mph... in 3rd? I can only manage 105mph in third with a massive torque spread!!Randell Floyd said:I'm in the Anglesey side of North Wales, might be worth asking Briskoda peeps for some kind of get together. I'd like too see how much faster mine is vs standard now, as when I turn the boost right down to full boost the difference is leagues apart.
I' sure the 0-60 has been cut from 7.6 to about 6.0 ( if not quicker ) as second gear can go from around 20-65/70mph very fast, third leads to around 125/130mph again very quickly ( as a S2000 can vouch for)
PMKeates said:130mph... in 3rd? I can only manage 105mph in third with a massive torque spread!!
rG-tom said:where are you from rhandell? im considering getting an octavia VRS if i get the new job i'm going forAfter seeing the price of them they've gone ahead of the leon cupra R
Tom.
Randell Floyd said:From North Wales, I'm in Gwynedd ( near Anglesey ) so I get some of the best roads in UK everyday
I'm currenlty on a year off from my season ticket with Man Utd other wise I would meet up before a match, but if people want to make the trip up this way for a drive etc I would be more than happy to come along.
In fact when I had a Intergra Type R we all met up and went on track in Ty-Croes ( currently Fifth Gear track haunt ).
Randell Floyd said:Ouch, mine was all done for £300 or that mark, turbo timer etc all included.
My mods are:
Full Cat Back Exhaust ( Blueflame )
100 Cell Cat
Carbonio CAI
Baileys DV30 Dump Valve
Boost Controller
Jabba Remap for Optimax
Didn't opt for the usual TIP as Jabba don't recommend it, and also no great use for a FMIC.
Kingy said:What's a turbo timer?
It keeps the engine running even after you lock the doors and leave the car, it allows the turbo to cool down properly by continuing to pump oil around
How does a Cat Back Exhaust differ from a full system? Why did you go for Blueflame?
It still allows you to have a CAT and thus pass an MOT test
What's a 100 cell CAT?
Its a high flow CAT. Its more free flowing but you will still pass and MOT with one
How does a CAI differ from an air filter? Which is best, cone or panel?
CAI Cold Air Induction. He has an induction kit which allows more air in. Cone or panel depends on the kit, normally panel is better
What does the DV30 do?
Its a dump valve, it doesn't do anything bar make a ppssssst noise and (about to open an argument here) stalls the turbo loosing you some power.
How does a boost controller work?
It can change the amount of boost pressure the turbo provides. More boost = more power basically
Why Jabba instead of Revo etc? Did you go for a custom remap, or a generic map?
What's a TIP? Do you have a FMIC, if so, why did you go for it?
How old is yours? How many miles? Any pics? Any reliability issues? What sort of fuel economy do you get? What gains are to expected from each mod, and what are the estimated costs of each?
Psycrow said:It still allows you to have a CAT and thus pass an MOT test
What are the downsides? Less Power, worse noise?
CAI = Cold Air Induction. He has an induction kit which allows more air in. Cone or panel depends on the kit, normally panel is better.
Is a CAI better than a panel filter? Are the differences just power, or noise as well?
Doesn't the stock engine have a dump valve? How is this one better?
How do you 'control' a boost controller?
So if a full system (is this the same as turbo back?) is more free flowing, even than cat back system with high flow CAT (I'm guessing this is a middle ground?), then how do the full system guys pass their MOT's? Would they need to refit a CAT, or buy an MOT? Or is it possible to pass the MOT anyway without a CAT?Liverpool-Lad said:1. More free flowing so will give more power.
Really, aren't CAI kits significantly more expensive? I've got ridiculously random preconceived ideas that a CAI is ~£250 as opposed to ~£70 for a K&N or whatever?Liverpool-Lad said:2. Id say no difference really.
Presumably this means that colder air is drawn in as a consequence of the different DV, meaning more power/better throttle response?Liverpool-Lad said:3. The stock one recirculates air into the intake, not to atmosphere.
Would this be in car, or under the bonnet? Other than a quick way of upping the boost for pod runs etc, what benefit is this?Liverpool-Lad said:4. Usually a dial/elec gubbins.
