Hey guys. Just finished my new computer
https://forums.overclockers.co.uk/threads/thermaltake-p5-build.18773436/
EK blocks and fluid temps of 29 degrees c under load with fans at half power. Idle cpu temps are low 30s.
I followed der8auers guide on YouTube to get the oc started.
I seem to have a stable 5ghz at 1.34v but I'm not sure about my temps and I cannot seem to get 5.1ghz even at 1.39v with prime95 non avx.
Real temps are currently: 81 70 65 66
But there was a point it randomly showed higher temps. The max were: 100 72 94 68
Which worries me a lot.
It's been many years since I overclocked anything so I'm basically learning from scratch again but if appreciate all thoughts on current temps and the erroneous high temps and if there may be a setting I don't have right that would allow me to maybe hit 5.1ghz
Cheers
Cheers
