So, yeah, there's been quite a bit of forethought/planning that has gone into this build,
So, when I said "prototyping (a.k.a. cocking things up and having to start again)", yeah, the back panel was one of those things that I had a number of runs at, mostly to get all the pass through holes plumb (six visible pass throughs plus another four for the pump/res).Is it wrong that I'm slightly disappointed those holes lined up so well on the GPU to rear block?! I figured it was going to be harder and I'm slightly upset by how easy you had it ;-D
.. (yet, at the same time, apparently it's quite normal to have about a gazillion handbags, etc.)
Thank you.Love how it glows, the dual Heatkiller Tubes just look so classy and the tubing work is on point. Great progress, it really has an industrial feel to it.
Thank you. As per @Cenedd the air gap in the top is for expansion.Ver nice Jay, must be a great Christmas present to finish it off.
It's come together beautifully, it's full but roomy at the same time.
One question (apologies if I missed it) any reason why there is about an inch of air on top of the Res? I will use this myself so wondering if there was an advantage to do it that way?
What I was trying to say was that I'm thinking of placing a strip along the back of the RAM block (mounted on the backplate of the GPU) to illuminate that as I think that would then add some light to that whole area. It would mean having a short length of cable trailing across the backplate but I think that wouldn't be very noticable. WRT downlighting from behind the top rim of the case - I've already got a Phanteks strip for that exact purpose (and two to fit behind the rims at the side too) as that was part of the original plan. However, when I was getting close to wrapping up I thought I'd first try a "less is more" approach to keep things clean. I'm going to live with it it a while longer to see how I like it before I think of adding these extras.If you mean putting some uplighting on the back of the GPU to light the CPU area, would you not be better with downlighting either tucked behind the rim of the case (where the glass panel sits against) or tucked behind the rad? Wouldn't show as direct in-yer-face lights then.
