I should really evaluate some other options on the MR2. I've always used R888s because they were cheap when we started out. Nowadays a full set of tyres is a significant investment that will last me a full season at least so I can't afford to buy something just to try them. The R888 is a known quantity that most of us use so I'm not losing anything by sticking with what I know but there could be an advantage to be had if I can find something better.
Based on your experiences what are your thoughts on the best road legal semi slick from cold? Most of the feedback out there is from racers/trackdayers where they have a chance to get the tyre up to temperature and have to avoid overheating them on a long run, for us sprinting, we want something that will be switched on immediately and our run is all over within 80-90 seconds so overheating is a non-issue.
I have a road / track car and have used many, here is some input from me as to how quick/easy they are to get heat into from my own personal experience of using them:-
Michelin cup: Best all out dry grip on track, OK for getting heat into and OK when warm in wet, useless in cold/wet conditions. Very expensive! Pretty low tyre noise which is why they are an o.e. fit on a lot of cars, GT3 etc.
AD08: The best for working from cold and the best in the wet too, but not quite the dry grip of R888 or cup. But as a positive cheaper and last longer. AD08-R is marketed as being better in both dry and wet, plus works even better from cold. I think the AD08-R could be your best tyre for sprinting.
R888: Excellent dry grip, pretty much on par with the cup and very good on lighter cars, whereas cup is more suited to heavier coupes/saloons. A lot of road noise though as a downside and can be hard to get heat into in the wet.
595-RSR: The worse for getting heat into and the performance of them when cold is shockingly poor, once heated up they are good in the dry and acceptable in the wet.
NS-2R: Not tried this one myself but the soft compound for sprint/track work is getting a lot of positive feedback, easy to get heat into and very good dry grip with OK wet ability. Medium compound last longer but harder to heat up.
Kumho V70R: Mate had these, rated them well but then he went to cups and did say the cups were better in the dry and easier to get heat into if that helps for comparison.
If I were you if you want guaranteed best for sprint, AD08-R seems a good bet, but if your willing to take a gamble try the NS-2R in soft compound.
