Mate is selling an E92 M3 race car he has just built and never raced. Very high quality build and going for a steal mate....
That is some impressive gains Gibbo. I have not read much of this thread so apologies as I am sure you have mentioned what mods you have done, have you put in new cams and done other internal engine work to get more power?
Will the CSL ECU add more drivability and response and not more power?
Mods are listed on the dyno sheet.
No engine work, no cams, just very well maintained, right oil, right level and only ever Shell Vpower.
Yes CSL ECU is for drivability and adaptability, it won't pull timing anywhere near as aggressive as the stock ECU does and will be a much smoother drive due to utilising a map sensor for lower rpm's.![]()
Ah, I should have gone to Specsavers!
That is epic gains from a naturally aspirated engine with bolt-on modifications. I bet she is fun to hoon around in! A proper little track weapon you have built. Good job!![]()
Yep, the acceleration is rather mind blowing, quicker than the 911 for sure, I love just cruising at say 75mph with box in auto S5 mode, floor it let it drop/blip down to 3rd and it just pins you and acceleration is relentless.
The dyno history is this:
When purchased: BMC panel filter, Scorpion catback exhaust, Milltek 100 cel cats: 336BHP
With Evolve remap added: 367BHP
CSL Exhaust fitted: 379BHP
CSL Air box & UD pulleys: 364BHP, ECU pulled ignition as car was hot.
Took it to Evolve to check OK: 370BHP on their dyno which is always less than Powerstations.
Today with de-cats at Powerstation: 393BHP first run, 385BHP second as ECU pulling ignition.
With the CSL in I do not expect to make more peak power but the ECU will resist pulling ignition as easy meaning I make all my power a lot more and the map sensor makes drivability far improved in lower RPM range.
Plus the ECU pulls ignition so quick on Powerstations dyno because their cooling fan simulates 60mph, the problem is as they dyno in 5th my car is hitting 170mph on the dyno, hence things getting hot and the ECU started to pull/retard ignition.![]()
Is the S54 strangled stock?
60BHP from just exhaust and intake bolt ons is a lot! As someone who has dabbled in N/A tuning before that is almost a 20% increase over stock.![]()
Why did it gain 23hp going from Evolve's to Powerstation's dyno - were some bits added? Kinda lost in the number of mods![]()
good old powerstation rollers eh
