Is that a brand name or is it just multi-purpose?I use Nads nose wax
Harry in the pub said Hookers and coke will sort it right out![]()
it's a brand, they do other waxes for other areas but the one I use is for the noise and can be used on ears too.... they are most famous for hair removal cream for the male parts... lolIs that a brand name or is it just multi-purpose?
Is OP still alive? Did you try any of the suggestions posted?
I'm not sure that that's an example of form follows function.I use one of these to keep my nose locks in check.
Yeah nerve endings from the roots don't go via the central nervous system instead they're plugged directly into the brain which is only a short distance above apparently. Damn difficult to avoid the temptation though they're so irritatingYeah, I've heard that plucking is apparently dodgy.
I'm just sick of the things, it's apparently not that expensive either so I'm really considering it. As far as I'm aware, it doesn't remove the hairs inside of the nose as you need them. It's more the annoying little sods around the edge of the nostril that seem to grow at lightspeed.
True.Yeah nerve endings from the roots don't go via the central nervous system instead they're plugged directly into the brain which is only a short distance above apparently. Damn difficult to avoid the temptation though they're so irritating
Ew.I probably need my head examined for posting this in here, but it's the most middle aged male populated place I'm aware of on the internet.
Anyone had this done? My nose hair is getting really bad over the past few years, it picked up heavily in my early 30's and now I'm knocking on 40 it's ten times worse. Waxing is hell, plucking takes ages and isn't exactly pleasant, using a trimmer leaves it feeling bristly and uncomfortable for days afterwards and I'm needing to do it two-three times a week.
It's honestly driving me up the wall to the point I'm legitimately considering a more long term option.
I thought hair in the nose was a significant element for filtering out crap from the air? Also the nose and the blood vessels there are very sensitive i'd be loathed to do any damage to them. Can't you just trim the hairs if they annoy you that much?
