- 26 Jan 2003
- Surrey
The TVs advertised as LED are only "edge lit" LED unless otherwise stated (some have a full LED backlight - but very few) so you get a nice thin TV but they suffer from clouding as the centre of the screen can't be lit as evenly as the edges.
In terms of power usage LED/LCD do use a fair bit less than plasma but since plasma is a self illuminating tech it doesn't always use up as much leccy - the peak will be for bright white images.
Best thing to do is get yourself down to a store and compare some sets - see if you are susceptible to the flicker some people suffer from on plasmas and or if you can live with the dark grey (not quite black) that LED TVs give you rather than the inky blacks of plasma.
If you aren't bothered about wall mounting the TV then LED isn't going to be worth the extra dosh as you mention - a normal LCD set would do you fine, although as I say go view some sets
