- 13 May 2003
- Warwickshire
Paint just won't seem to adhere to whatever's under there.
Famous last words.Any thoughts are gratefully received, thank you.
Would be interested to know if you can actually fill that bit of ceiling to sort it. Ive got similar from aj electrician putting a hole in the wrong place and it's never looked quite right!
Ah fair, mine was onto a freshly skimmed ceiling! :XI'm getting the ceiling skimmed once all fixed and I've scraped the paint off, so it doesn't matter if I can hide it or not.
Doh.Ah fair, mine was onto a freshly skimmed ceiling! :X
Get a fan heater in there if you have one, try and dry it out.
Also wouldn’t silicone personally, would make a tiled hatch but each to their own![]()
... good stuff
ultimately I did not understand logic of cutting ceiling - I had thought floarboards had been cut beneath bath to help with bath clearance/installation,
so this would give visibility, but if not, it was always going to be necessary to remove a tile ? so do that first.
