anyone got any discount codes ?
wouldnt let me use the 10% discount code so had to pay full whack but oh well, glad they finally have it in stock
Damn, will have to do the same then.
Ordered the 3070 spec
nice! What other options did you choose?
I went for the finance option and it left me on a pending screen (which said ‘success’ but had a spinning wheel which still hasn’t stopped or reloaded)
I called support to confirm and they said it will be updated in due course and I’ll get a follow up email to confirm. Hoping it all works out as I’ll be gutted if I’ve missed out.
Same specs here, thought might as well get all the extras given i want it to last a good few years!Went for:
AMD 5800
32gb
3070
RGB keyboard
What did you choose?
Actually was fortunate enough to have one of these in-hand from the electronics high street retailer but decided against opening it. Gave them the chance to price-match it but I'm just outside the 7 day window for this and they weren't budging. So I've ordered a new one online instead and will return mine.
The original order was £1500 for the highest spec CPU / GPU and 16GB of RAM with 1TB of NVME storage. Have ordered the same machine online with 32GB of RAM and 512GB of NVME storage (plan was to upgrade to 2TB anyway) for a nice ~£125 saving. Hoping if I can sell the 512GB NVME on, I can use the savings to buy a 2TB NVME and all-in pay the same ~£1500 for a much better spec-ed machine.
Does anyone know if the 2x16GB configuration of RAM suffers the same performance woes (non-native res) as the 2x8GB RAM? I couldn't see anything on it when I went looking.
2x16GB is dual rank so is the ideal config, it's what I've got but mine is currently being fixed under warranty.
Thanks. Hopefully you get your issue sorted soon...
32GB will be overkill but looked at the price of 32GB kits (and availability!) and the +£50 cost seemed reasonable enough.
THat was my logic too.
I really like the laptop, mine wouldn't output any audio intermittantly though so waiting for it to be fixed. Will ask for a partial refund for the hassle.
Yeah I had read about your issue earlier in the thread but was hoping it was a one-off sort of a thing. Not really an ideal start to the ownership of it regardless.
Someone has probably already asked but did you not get offered a straight replacement, given how new it is?
A question for those of you who have your 5 Pros - have you found a decent case for it? I'm really interested in man-bag/messenger style bags but would like to hear about whatever you've found.
