Will Richer Sounds or John Lewis price match with QVC so you can get a longer warranty?Keep in mind it only has a 1 year warranty.
I tried and didn't get on with a 60cm desk, so wall mounted the TV and swapped to a 80cm desk and now pleased with my set upDoes anyone run one of these with a 60cm deep desk? I am concerned about the distance and playing FPS games. I can wall mount but don't want it to be too close. I have a 65" C9 in the bedroom, so know how gorgeous the display is.
According to the HUKD thread RS are not price matching as the warranties are not comparable. Hope you have better luck through your friend.I have a friend who works for RS, and will ask that very question tomorrow as I want one - will let you know.
I think wall mounting with a deep desk will be optimum, as has been mentioned above. Even on my 88cm desk, bopping my current TV on it to get ‘the gist’ of how it would look made me think it was way, way too big and would have to be wall mounted.Does anyone run one of these with a 60cm deep desk? I am concerned about the distance and playing FPS games. I can wall mount but don't want it to be too close. I have a 65" C9 in the bedroom, so know how gorgeous the display is.
Yeah I think 48” is too big for my desk. Thanks for the advice. I’ll grab the Alienware 38” until a 42” OLED comes out
42" oled would be awesome
For me personally, I don't actually want to use an OLED screen for anything other than gaming & media. Now that I'm used to 48" with a 800mm desk then I'd see a 42" OLED as a bit of a downgrade.
I do miss my Acer 34a for first person gaming so an OLED ultra wide would be amazing but I think probably a bit too niche.
I use my 48 and switch between that and my ultra wide which I use for work.
just wondering if anyone has any ideas on why when I change monitor that it doesn’t switch to 10bit 4.4.4, I have to reboot to get this.
im on a Radeon card, it’s a minor annoyance, but would be great to bypass to stop having to reboot when I change over.
