LG 48CX OLED - 4K 120 Hz
Hello guys have had this Tv for a few years mostly for pcgaming I just read about Bfi Is this a useful feature for me when playing games online or singleplayer?
I use it on my CX for gaming and it really does make a noticeable difference in motion clarity, i have it set to minimum level as the higher you go the more brightness you lose.
Try it and see if you like it,
Thank you pee head I tried and I cant use vrr anymore does that effect gameplay?
does using true motion give less input lag?
and one last question I read it has to be high to double refreshrate?
VRR is good if you can't maintain high frame rates in games and yes you can't use both VRR and BFI at the same time.
Input lag with BFI should stay the same as long as your in game mode or PC mode.
BFI works at 60hz or 120hz.
How does it look and feel to you ?
Anyone with dead pixel issues? I've been using this as a monitor/console TV since 2020 and only just noticed the odd dead pixel along all 4 edges of the screen while cleaning it the other day. Nothing too bad or even noticeable at a normal distance away. I saw online some people blaming screen shift for a similar edge dead pixel problem but much worse, like big blotches worse.
Its inherent in the technology itself as its very difficult to do perfect no dead pixel manufacturing.
