Bananadude said:It pretty much was the only concern I think! Silly really! What are these 2-3 bay extra fan/hd bays you mention? Do you mean like THIS ONE - that's just one bay though and I thought these got hidden behind the blanks anyway? I definitely would want something for the blanks - without spending a fortune. I'd go for the black version of this case though, so whatever I get would have to go with that. Thanks fof the pics - I'm definitely leaning towards the V2000, just need to figure out what to do at the front!
normski_ said:You can get blanks that look like the rest of the perforated front as well, which opens up all sorts of options for 3rd party drive bay fans such as the Scythe, allows the air through nicely and you would be able to see a coloured fan etc. nicely too.
Anyone got the TR3 fan/temp display?
dangerousmouse said:can you give any more info on these drilled blanks?
also interested in the fan controller, just got my v1000 this week so i will most likely be purchasing the controller (very) early next year.
EDIT: i am still looking for pics of the lian li controller 'working' i want to see what the display is like, i will only buy if it is blue. (im a bit picky!!)
What would someone type into a popular search engine to locate such an item?normski_ said:The blanks are official Lian-Li blanks that aren't showing on their website. I can't post the link to the few sites that I have found them on, as they are competitiors. But basically they look exactly like the rest of the front of the case, ie. they have holes in them, and look just like on the new A-16:
The duct is completely removable on both cases.Bananadude said:...I can't see a problem with it fitting, although I thought it may pose problems with the V1000 given the position of the air duct....
Bananadude said:Look forward to seeing those pics!![]()
Another question for you - would a 45cm SATA cable be long enough for either of these cases, or would I need the 60cm or even 100cm one? I have a couple of 45cm cables, so just wondering if I need to get longer ones for either the V1000/V2000? Would I get away with a 45cm IDE cable for my DVD drive also?
normski_ said:Interestingly, am just looking at the Western Digital cables that clamp onto the drive.
Bananadude said:They will be sold as the Plus version it seems, as apparently the boxes for the Plus II don't say so, they only say Plus. The ones OCUK are selling say Plus on their site, but people have reported they've received the Plus II. You may find this is the case in most places. Once stock of the Plus runs down, the Plus II's will take their place I imagine. Not sure if Lian-Li will be changing their packaging sometime soon - confusing for distributors and customers otherwise.
