okimanoob said:http://www.tagworld.com/okimanoob/PictureDetail.aspx?id=61096785-3b1d-483b-a458-3ec07d0cb238
I use the WD Sata cables on the two WD hdd's in my V2000 - they reach to top of mobo no problem - just reverse the hdd so cables are out of sight and routed up back.
Massive Attack said:@ Normski, just wondering can u take the wheels off you v2000?
cheers
dangerousmouse said:how have you managed to do this. i have a v1000 ,and have just spent best part of an hour with it in pieces trying to get the cages mounted the other way around. no matter how i seem to build it back the hdd's still project too far out for the cables to plug in, and for the panel to go back on.
unless i need to drill some holes, and re-mount the hdd cage closer to the rhs of the case...
intresting...... do i get a v2000 or a 201B??normski_ said:yes yes![]()
