- 23 Jun 2004
- Blackburn
It actually tells you on the lian li product page...
O11 DYNAMIC EVO - LIAN LI is a Leading Provider of PC Cases | Computer Cases
Keep cool with the O11 Dynamic series all-new design and express the preferable configuration. REVERSIBLE CHASSIS MESH PANEL INTEGRATION FLEXIBLE CONFIGURATION OPTIMIZE COOLING SUPPORT 9 DRIVES CAPACITY CABLE MANAGEMENT FRIENDLY 5 OPTIONAL ACCESSORIES GERMAN ENGINEERED...lian-li.com
Scroll down to the Spacious Cooling Support bit
I saw that but was a little confused. Top and bottom positions is obvious, 87.5mm but the side has mulitple measurements. Inner scenario max thickness? Does that mean when the radator is in the back chamber? psu side? That says 83mm total thickness which I assumes includes radiator and fans on the the mobo side. Thing is srekal34 looks to have an EK Coolstream XE in that position which is a 60mm radiator so according to Lian Li is wont fit with a 25mm fans as it would be 2mm to wide
