Lian Li O11D- Mini....(latest post with AIO Up top in ATX format)
Yep, should only be horizontal if at top and tubes at bottom if vertical. Thinking of the Crosshair DTX as a halfway house between ATX and ITX, kind of fits in with the Mini not being quite an ITX case. I'm assuming I'll then be able to fit a 360 AIO and still have room for fans at the bottom.
https://preview.redd.it/d265w9ertk5...bp&s=bff025fa96956c2ff1f9253363d6a098e7db5a67
interesting . wanted to use 20.5mm thick XSPC up top with 15mm fans using ATX board.. seems it will work .
hunting that board. Gigabyte vision, the DIMM Latch has to be inline with the middle mobo mount hole
https://www.gigabyte.com/FileUpload/Global/WebPage/654/img/02.png
looking at gigabyte Gaming X of the same chipset , can see the latch is slightly higher so ram would class using 25mm fan and 27mm rad
https://static.gigabyte.com/StaticF...9748f103eec4efcfe0157/Product/25726/webp/1000
Finished my build! Vote me up if you can:
https://www.reddit.com/r/lianli/comments/l8o1pe/black_purple_011_mini_build/
This was such a long time coming, very satisfied it's done.
What a stunning build. This is is something I'm hoping to do for my system.
I upvoted your reddit post. Any chance you could do a full part list by number? I definitely want to do this too and it would really help me immensely in the planning.
Also, what did you use for the hardware monitor screen? Any links to where it is sold in the UK? Never seen anything like that and it looks amazing
