- 11 Mar 2016
Hi
About 2-3 years ago i built this purley for Doom.
It started off red, then i changed the fluid around, you can see the build log in my Sig.
Today I'm embarking on the new build due to the release announcment of Doom Eternal (nov 19)
I have ordered the LIAN-LI PC-O11 Dynamic White
So Far my shopping list is being built and consists of;
lian li o11 dynamic water cooled
rog crosshair viii formula x570
AMD Ryzen 9 3900X
GeForce RTX 2080 Super
Corsair HX1000i
DOMINATOR® PLATINUM Special Edition Torque 32GB (4 x 8GB) DDR4 DRAM 3200MHz C14 Memory Kit
Samsung 512GB 970 PRO V-NAND M.2
VG271UP ??
360mm Radiator
Bitspower Touchaqua Sedna O11D for LIAN LI O11 DYNAMIC (PWM)
TBC
TBC
Bose Compaion 50
LL120 RGB 120mm Dual Light Loop White RGB LED PWM Fan — Triple Pack with Lighting Node PRO
Im not sure about the monitor yet, but adjusting as i go.
AMD Ryzen 9 3900X
Corsair HX1000i
VG271UP ??
360mm Radiator
TBC
TBC
Bose Compaion 50
needed ! just better airflow and plugs gaps in psu and main chamber if running negative pressure
