subbed ..colour and model of my second choice.... will i change my mind.. GL with the build, sounds exactly what I'd be looking at... fancied a white and uv build with RGB back up for a change
nice! monitor stand is such a heavy beast ! i wasnt expecting it to be that heavy .
update firmware and nvidia drivers and monitor is golden
Where can you get the monitor firmware?
Also im really struggling on what fluid to put in the system i want yellow but i dont want all the crap of clogging!!!
once you've installed software for it and connected USB cable from monitor to Mobo- you should find you can update it from there
just ordered some G.SKILL Trident Z Neo (For AMD Ryzen) Series 16GB (2 x 8GB) 288-Pin RGB DDR4 SDRAM DDR4 3600 (PC4 28800) Desktop Memory Model F4-3600C14D-16GTZN
https://www.newegg.com/g-skill-16gb-288-pin-ddr4-sdram/p/N82E16820232856?Item=N82E16820232856
Should have that next week or so![]()
