Lian Li V1000+ & Tagan Easycon PSU
4 Jul 2006
London
Hi all,
Planning to build my first rig soon and was thinking about using a Lian Li V1000plus case with a Tagan TG580-U15 580W ATX2.01 Easycon SLi Compliant Modular Silent PSU (CA-009-TG).
I've noticed the V1000+ has an upside down configuration with a distinct PSU compartment. The Tagan also has a 120mm fan adjacent to the rear grill rather than a smaller fan on the opposite face. It is also modular. Can anyone foresee any problems I might have using these two together?
Thanks for your help.
It will work fine, but you may have to take one of the hard drive bays out, limiting you to 3 hard drives.
If you need more hard drives than 3 you do not really need a modular PSU. :)
If you want me to post some pics give me a buzz and I can post some for you. :)
If it is tommorrow I may take some time as I should have the Lian Li S80 to play with!
She is not here yet, why now is the best time. :p
Was there something you didn't like about the fans that came supplied?
What does the readout on the TR3A tell you?
I hope mine looks that nice when I've finished bodging it all together!
Thats mine without cable tidying, looks much nicer up until today when I made it ready for the new case!
TR3a shows fan speed, temperature, time and hard drive activity.
The fans I replaced with ambers, my rig is silent during normal windows use and a bit noisey for games. What my main aims were.
I'm sure this is a silly question, but is voltage something I need to decide upon for my fans? I just thought they plug in and revolve!
Thats how they work, plug them in to a 12v molex and away they go, at 12v so full speed.
You can mod them, so that they only use 7v or 5v from the molex, making them spin a lot quieter but push less air.
I see.
A bit of a change of topic, but do you have a special set of tools you use when you build PCs?
I have one or two screwdrivers around the house, but they're a bit log really.
I noticed Victorinox make a special 'techy' swiss army knife:
The Cybertool
I don't have anything that small, although I'm sure I'd find a way to set dip switches without resorting to their 'pressurised ballpoint pen'
