Edit2*
Found the link to "Lightroom 6" - Always confusing CC with x.x versions. Must remember, x.x is standalone, Package CC is cloud install $79 to upgrade from 5.7 to LR6. not bad.
This link: https://www.adobe.com/uk/products/c...talog_sl_software_sl_photoshopcollection.html
Click the "buy" link and then select the dropdown for "I want to buy" and select "Upgrade"
I'm noticing LR6 is snappier, it is loading my RAWs in the develop tab quicker and dossing about the modules is quicker too. I'll know just how well implemented GPU acceleration is when I come to exporting this big wedding set later on though. This is where that feature should come in handy the most.
After using this all evening it does appear to be a bit faster which is always handy especially when my iMac 5K arrives. There are features that I like such the filter brushes, collections etc but overall I'm a little disappointed.
If you tack on VSCO keys then you also have fast keyboard editing like Capture One..
Capture one seems like a really great piece of software and images look great in it (was testing it in case LR was going to be CC only). However I don't currently have the time to go through it's learning curve and customise everything to how I like it. There is something to be said for the simplicity of lightroom. If you tack on VSCO keys then you also have fast keyboard editing like Capture One.
