- 3 Oct 2014
When they are digging up pavements, how does the fibre get to your house? Over the telephone lines?
Well it’s a totally separate entity to Openreach so they wouldnt let them use the telephone lines (but they are copper anyway)
I’m assuming they do what virgin media do and dig from the street to your property?
Hi, Dave C here, I'm in Weston Coyney, lila have just laid their fibre down the centre of our pavements. I took photos. They laid the blue fibre optic cables at the bottom of a trench that they dug, approx 6 or 8 inches deep, by approx 5" wide. Then every two houses they branched the trench, and cable to the properties boundaries, in my case a wall at the bottom of our drive. There the cable was attached to a junction box. The trenches were then filled in and tarmacced over. I didn't see any ducting whatsoever. I've registered an interest and await feedback from lila, I'm assuming that they dig a similar trench to our front wall and enter our house through that. Could be a pain because we have block paving.
Hi Dave - strange that - so you're saying they put the actual cables in the ground and then tarmac over them?
Our guys had a massive reel of purple corrugated 'ducting' same as you see up the side of the motorway when they are doing roadworks - which was put in the ground and linked up to some 'inspection covers', then a smoother narrower pipe also went in (not sure if this went in the corrugated stuff then put in) then tarmac'd over
I understood that someone else would come and actually pull the cable through these ducts at a later point in time.
Hi if you email me tell you if you live yet lot of homes live now.
You get a survey done and they go throw install with you for best route for you.Some streets in Weston Coyney can order this now, mainly Park Hall area, I'm hoping that I can soon too.
How does the installation work from that little black box on the path just outside property boundary? It's roughly 4 meters from street to my door. Where does the fibre cable get installed to in a house?
Hi air broadband who work with Lila connect are doing the £49 fibre installation booking free till jan 2021 and they doing £34.99 for 18ms with the £10 Lila connect fibre cost £10 per m so £44.99 or you can pay £650 instead of £10 per m. And give one ms free for install done by 31 dec 2020 so can call them on 01223 653400 or email them hope this helpsThanks. Is that the £49 Fibre installation booking? Then if happy, I would pay the £650 for it to be installed?
Hi most work in stoke is underground not on poles. Vx fibre is all on footpath and easy to install straight forward. Work in this industry any question feel free to ask
