Looking to build for msfs2020
7 May 2012
Bracknell
Hi there can i ask peoples thoughts on this build that's been recommend please to me by a kind member.
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor
CPU Cooler: Thermalright Assassin Spirit V2 Plus 66.17 CFM CPU Cooler
Motherboard: ASRock B650M PG RIPTIDE Micro ATX AM5 Motherboard
Memory: TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6400 CL32 Memory
Storage: Lexar NM790 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive
Video Card: ASRock Challenger OC Radeon RX 7900 GRE 16 GB Video Card
Case: NZXT H5 Flow ATX Mid Tower Case
Power Supply: Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply
Total: ~£1360
Total: ~£1360
Do you definitely want an mATX board? Will look quite tiny in a mid tower case,
Is there a reason you've gone for the asrock riptide?
Tbh your list of parts is very good can't really recommend much as an alternative.
Are your going to be able to build this ?
I think i could probably do it as i have done upgrades on my current rig ie: cards chips and memory, been saving for a year
This is what i have at the moment
1 x Intel Core i7-8700 (3.2Ghz) LGA1151
Air CPU Cooler
1 x Raijintek Aidos Direct Contact CPU Cooler
RAM
1 x Corsair Vengeance® LPX 16GB (2x8GB) DDR4 DRAM 2666MHz C16
Graphics Card
1 x NVIDIA GeForce® GTX 1070 8GB GB
Motherboard
1 x ASUS PRIME H310M-E (Socket- 1151, 2x DDR4, Micro-ATX
Storage HDD / SSHD
1 x 1TB 3.5" SATA III HDD
SSD
1 x ADATA XPG SX6000 256GB M.2 PCI Express 3.0 SSD
Optical Drive
1 x Asus DRW-24D5MT 24X Internal DVD Writer
Add-on Card
1 x Wireless PCI Express Adapter 300Mbps
Case
1 x Corsair Carbide 100R Windowed
power Supply Unit
AeroCool® Integrator 500W — 500 Watt 80 PLUS® Bronze PSU
Air CPU Cooler
RAM
Graphics Card
Motherboard
Storage HDD / SSHD
SSD
Optical Drive
Add-on Card
Case
power Supply Unit
That's still a capable 1080p gaming pc.
There's nothing wrong with the parts above apart from the motherboard being matx which @sx_turbo pointed out.
asrock was recommended when they came up with a build, would something else be better then?
No it's fine, just mATX is a small form factor motherboard.
It might look a little lost inside a large case, and it won't have as many upgrade slots.
The Asus b650 plus would be a good alternative option
oh cool upgrade slots would work better I'd say to future proof.
Is It this one please
What's wrong with the motherboard please as i would not no sorry.
Nothing wrong is just the one you have chosen is micro ATX and the case you want us ATX, it will still fit but looks small in your cae
Either get an matx case or atx motherboard or do nothing.
You can get the WiFi version for the same price so you have a back up network and Bluetooth.
Forgot to say going from what i have been told to get i can't seem to find what i think are the right items like the cooler, I must be mssing something, also maybe change the case to something not as big If my motherboard is so small.
This I what i have got in basket so far.
