Low Frames On New Build
Finally got my HDD and installed windows 8. My pc is much faster now, when booting up and stuff. :) now i just have to install steam and install some games which could take a while because i have a crappy internet connection loool :D
Nice, be sure to tell us if it smooths things out.
Yeah, and im getting 60 - 70 FPS on minecraft...
Hmm, so a slight increase in Minecraft then? I honestly think it could be something to do with the RAM in that case, it should be running on the XMP profile. It's designed to run on it, yet you're unable to play any games with the XMP profile running? If that is the case, try and run with the XMP profile enabled again, and see if there's any difference now that you're running Windows 8.
I turned it on and its exactly the same FPS in minecraft :(
May sound daft, but have you got the correct motherboard drivers installed?
i.e. not just running off the 'Windows-own' drivers?
Download the latest board drivers from the manufacturers website, install those and see if there's any improvement.
