- 4 Aug 2007
- Wilds of suffolk
Its interesting there is some dispute if the cause of most car fires is electrical wiring faults or fuel system faults
I don't think that is true.A diesel car can never be the cause of a fire.
It was a diesel RR Evoque. There are pictures and videos of it. So what significant implications are talking about that need to be applied to the types of vehicles that have caused this fire and the many other huge recent fires like the one in Liverpool and Norway?If it does indeed turn out that it was an EV that combusted, destroyed a car park along with over 1000 other cars, caused planes to be diverted and disrupted an airports operations then the knock on implications would be enormous.
Concerns would be raised (quite rightly) regards the safety of parking EV's in all multi story car parks around the country, including all other airports, ferry travel, channel tunnel, below ground parking in apartment complexes and on and on it would go.
Hence it will be declared that it was an old diesel with a leaky tank/loose wire/dodgy MOT and all the above implications will go away![]()
Agreed. The recent fire of an EV Vauxhall van in Liverpool was not to do with the battery but dodgy Vauxhall wiring that had also been seen in fires of Zafira's.Its interesting there is some dispute if the cause of most car fires is electrical wiring faults or fuel system faults
I've seen plenty of turbodiesels with runaway engines on fire that suggest otherwise. EVs and Petrol cars don't runaway like diesels.A diesel car can never be the cause of a fire. There has to be an ignition or heat source to create that fire. If it was Petrol or EV the result would still be the same.
I mentioned Vauxhalls earlier. IIRC correctly there was a wiring issue behind the glove box / heater area that over time created a very clear fire risk.Agreed. The recent fire of an EV Vauxhall van in Liverpool was not to do with the battery but dodgy Vauxhall wiring that had also been seen in fires of Zafira's.
I honestly don't get what this tribal bickering is all about, the way people attack and defend stuff that is of absolutely zero consequence to them makes no sense, you'd think there's some kind of award or something for it.If you follow the FUD constantly run by many newspapers and spread online you should realise that they would have been going on about it for weeks if it was an EV.
If you do want to follow it, follow Bobby llewellin (spelling!) of red dwarf fame. He often posts about them and sometimes they are hilarious.
Like the one a couple of months ago about a flood killing an EV, along with photos. When the car was very much NOT an EV.
Evoque fire risk persists despite recall
My wife loved her Evoque. Unfortunately it went up in flames last month and this is to warn all Evoque owners that the fire problem does not seem to have been sorted by JRL. The recall was performed on this car 6 months ago yet while still under JRL waranty thisEvoque started a fire while parked...www.evoqueownersclub.co.uk
So you're trying to tell me there's nothing in the whole of a car which can cause a spark and therefore provide the heat in your primary school example?
This is a weird hill to die on.
There are known recalls for Evoque's, some based around fire risks.
No one's arguing that, but that's not what you've said.No I am telling you that the cause of the fire cannot be the diesel itself.
No one said it was.No I am telling you that the cause of the fire cannot be the diesel itself.
Exactly a battery cannot be the cause of the fire. The EV Vauxhall van would have gone up in flames if it was petrol or diesel regardless.
No one said it was.
A battery absolutely can and has been the cause of many fires. Internal shorts absolutely happen and have caused fires. Ask note 7 owners or those who owed a number of scooters and bike that subsequently burnt down their house.
Edit it’s literally the premise behind the whole EVs catch fire FUD that’s represented in this very thread.
You said "a diesel car can never be the cause of a fire". Yes it can because it's not just made of diesel is it? And does indeed contain things that could ignite the diesel.
Surely Brexit, Elon Musk, Donald Trump, Rishi whatsisname, the Chinese virus and climate change have had some detrimental input to this disaster, it can't all be down to the technological weaknesses of vehicle fuel systems?![]()
