Like I said. This is like Liverpool. That wasn’t an EV. EVs are still much less likely to just catch fire regardless.Not spontaneously, IC cars very very rarely catch fire when they're just sat parked. This seems to be EVs forte
Who’s to say the car was just sat parked at the time it caught fire?Not spontaneously, IC cars very very rarely catch fire when they're just sat parked. This seems to be EVs forte
Range Rover went up so quick it looked like it “exploded” is the report.
Not confirmed but eyewitness reportsSource?
It will have now…Has Luton airport still got a massive amount of construction going on?
Citation needed….ICE and EV need to be separated in car parks. EV seem to have a higher likelihood of spontaneous combustion and ICE seems to be safer but provides fuel for the fire.
Actually completely the opposite way around. At least 20x less likely to catch fire than an ICE vehicle. Perhaps we need to space the ICE vehicles out more. The fuel leaks out when the fuel tank melts and sets the cars around them on fire and the ones on the deck below. It also heats the structure of the building up and causes it to collapse just like it did in Liverpool which destroyed nearly 1400 cars. Looks like the same has happened here with 1200 cars.ICE and EV need to be separated in car parks. EV seem to have a higher likelihood of spontaneous combustion and ICE seems to be safer but provides fuel for the fire.
No. It's common sense.Citation needed….
So far I've seen two theories on twitter
EV's and "Muslims"
Completely the opposite way around? What fuel does an EV supply that combusts if the car next to it catches fire?Actually completely the opposite way around.
Not one that pours all over the ground and gets into the structure of the building and decks below. https://www.newcivilengineer.com/archive/liverpool-car-park-fire-a-perfect-storm-02-02-2018/Completely the opposite way around? What fuel does an EV supply that combusts if the car next to it catches fire?
Yes that was my point. ICE provides the fuel for the fire. So I'm not sure why you are suggesting it is "completely the opposite way around".Not one that pours all over the ground and gets into the structure of the building and decks below. https://www.newcivilengineer.com/archive/liverpool-car-park-fire-a-perfect-storm-02-02-2018/
