- 8 Dec 2002
- North Yorkshire
I've got a MacBook Pro 13" Late 2015 and the bezel has what look likes grease around the edges even though it isn't. It look like the glue has maybe peeled away. I have AppleCare to cover this I would assume, however this is where it gets complicated.
I took my charge out of bag and the plug landed right on the Apple Icon on the bag of the screen and smashed the plastic. The screen is OK apart from a very feint mark which is only visible on what backgrounds on the screen. Is this likely to be due to light being able to escape from the back of the screen and therefore giving the imperfection ?
Finally what's the likely outcome with Apple ? Would they have to replace the entire screen to fix the black bezel issue which would then fix the back of the screen ? Or will they be likely to charge me for it and if so how much is it likely to be ?
<IMG SRC="http://imgur.com/a/Ufyim>
