Machine dead :(
Until this my IP35 Pro has been amazing - I cant beleive I've had it since 2007. I have never, ever gone so long on the same hardware setup and still found it to be lightning quick, run the latest games etc.
I think the XFi thing is a driver issue so I booted into Safe mode and removed all the drivers, now downloading new ones.
Other than that everything seems ok so far. I cannot for the life of me understand why though, it makes no sense.
Did you put up the ram voltage after CMOS reset. You may need 2.0- 2.2V which may be causing ram problems.
I've had similar issues with this board where it will give an random error like this
sid
[TW]Fox;18129210 said:
Has been fine since my last post. Even played some games.
:confused:
Well, that's good news! It means you can replace it as and when you see fit. Hopefully it never fails!
Just like I always say, today has been a good day, I've not gotten a splinter, touch wood.
Well a week on my PC is currently sitting here with 5 days 4 hours 11 minutes of uptime. No problems, no hassle, working fine.
I've still no idea what was wrong - but I'd like to thank you guys for the suggestions anyway :)
Don't worry about what was wrong....It works now! :D
Haven't read the whole thread fox, but my ip35 used to mess about every now and then. It was a case of removing all the ram. Clearing the CMOS powering up with 1 stick in place then shutting down and re-fitting the rest.
Really was an odd board.
Glad to hear you got it working now though. BoMb_Da_BaSs
