- 27 Jan 2009
- Oxfordshire
Short clip of an attack on an oil camp
Mad skills I know
Mad skills I know
!Using mouse and keyboard with no issues.So whats everyones preference for this, keyboard and mouse or gamepad?
I turned the fps limiter off to see how well the Fury (non-X) does with every setting manually maxed at 1440 through vsr on a 1080p monitor and it stays above 100 fps which is great to see,
had to muscle off 2 very tough cars that just wouldn't give up. I ended up doing a kamikaze move on one and had to bail out as he exploded, the other guy then kept trying to run me over. I managed to roll out of the way and take him out with my last shotgun shell
anyone got there Ripper body yet im at jeets place but not ripper body has unlocked ? i payed for the pre-order mad max + ripper body
Check that first , mine installed last night , You then go to garage menu and look at the car bodys , it will be the last one, select this and done
It will tell you in the Steam menu if its installedCheck that first , mine installed last night , You then go to garage menu and look at the car bodys , it will be the last one, select this and done
