1. I take it you own a sapphire 6950 reference model? or is it a 6950 toxic or something ?
2.With gpu-z can you confirm that the bios switch has unlocked the shaders from 1408 to 1536, also do you clocks rise from standard 800/1250 with the bios switched over.
3. standard vcore for default 800mhz 6950/6970 is 1.1v, and 1.175v
So you may need to increase your vcore if its at 900 with 1.1v.
