MAJOR Superpi - Survey
weescott said:
Get some ye-olde BH5 and watch the seconds dissapear. Or even try a higher multi!
Or better get some good TCCD ram and get the settings right. My 4800 Gskil is flying... it can do 325HTT at 2.5,4,4,8 with only 2.9v - but you have to get the settings absolutly right :)
PS... Weescott, why is my score below a slower one???? Also for info CPU at 313 HTT not 310... Ram at 1:1 - should have more to come :)
I have been doing! Can't get it Prime stable at 200*11 and it won't load windows at 1.75v (not tried higher).
Any ideas? I've only got tonight left with it really, so unless I leave my new system bits alone tomorrow I won't be playing with it after today.
EDIT: Here's my 8m Super Pi time:
Same speed/timings. On air as well, incase you were in doubt.
8M result here
SimonMaltby,
we are interested in 1Meg results , 8meg is a bench thats hardly gets used anyway.
It seems always 1 or 32meg.
<edit>
NM m8, just seen that 8meg has been added.
Would have rather seen 32meg myself.
dangerousmouse said:
partially over the 45 seconds, but i see that others have posted who are into 50+ seconds.
I just added the request in as I don't want hundreds of stock results choging up the table. :)
get clocking ;)
43.250 seconds... not bad for an XP1700
It's Older result (Untweaked), this rig can do 39... but it'll do for now
{Edit}
Saw it was millisecond only... so here's another one should just scrape under the 45 second limit
update then under 45s
athlon64 3500+ (winchester) running at stock 2210mhz cooled on air
mem timings 2.5-3-3-8
EDIT: although looking at the pic, cbid is reporting the cpu @ 2211.4hz??!?!? seems to of overclocked itself slightly (only slightly) gonna try and take it up to 2600 some point soon, only i am supposed to be packing to move house.
o/c pc Vs move house hmmmmm/ i know what i would rather do....
EDIT: Update, just put my most stable overclock one up instead.
This is at 2.72Ghz with Ram running 5-2-2-2.0 timings, on air still.
Ta!
