So I just started to use them and I'm getting used to it a bit but can anyone give me any tips.
How an you tell when the appropriate moments are and what should you do during corners do you gear down when going in and then start to accelerate a little then gear up at exit?
I'm 12 no license it's against the law for me to have a license.
that explains a lotOn a pad its always best to use auto its just easier.
+1
It is not fun doing manual gears with a pad or with a rubbish steering wheel.
