Not here to say one is better than the other but things to consider
57% of the SAS are made up of ex paras
Para 1.5 mile run time has to be below 9 minutes 30
RM's has to be below 10 minutes 30
Crikey there is hope for us all, i'm 38 and i reckon i can do 1.5 miles in 9:30. Young lads of 18 should not find it a problem.
For Marines it's a 3 miler.
You do a 1.5 mile run as a troop at a moderate pace, then best effort return 1.5 mile which is what counts. I don't know if it's the same for the Paras.
There are more demanding physical tests than a 3 miler on the courses.
It's all irrelevant really though as it doesn't tell us anything about the final products.
That holds little value...
If you turn up at the RM training base and get a 1.5 mile run in over 10 minutes you're unlikely to pass the course.
Wonder what % of the SBS are Marines...
All entry times for every regiment are 1.5 mile squadded run by 1.5 mile best effort.
Your likely to be binned from paras if you do anything over 9 minutes anyway
Anything over about 9mins and you are likely to get booted and that is after doing 1.5 in under 12....as you will soon find out...
I know a bunch of RM who have breezed trough the PRAC, but quite a few Paras who struggle with the PRMC.
If you look at what the PRAC consists of, you would have a little smile on your face tbh......a bunch of sit ups, a bunch of dips and heaves.....a 5 mile run and a couple of circuits of a steeple chase.....compare that to the PRMC, EdGey and giggle.
The PRAC consists of a 3m followed by a 1.5m....however the rest of the PRAC is nowhere near the same level physically as the PRMC.
lol what makes you think the prac is any less than the prmc
PRAC is also 3 days and entails more running than prmc does
your opinion mine differs![]()
Nah mate, the 30miler was the killer for me, endurance course isnt that bad.The endurance course is the real tester from what I've heard.
Is the RM course still have the longest basic training in the world ?
