I'm really really tempted by this board, it had a great feature set, clearly clocks well, the software looks superb, and it's BEAUTIFUL looking board but never had micro-atx before and I'm and I know this will sound silly, but won't a micro look a bit odd in a Corsair 650d Obsid case?
Secondly and much less silly is my concern about temps during SLI with the slots being quite close together?
Thoughts?
Thoughts?
The board performs great your correct on that one. As far as looks goes its all personal tastes mate. I had it on a massive bench table that will fit an EVGA SR board for ages and to me it looked fine but its your rig and your tastes so you need to decide on this.
Hmmmm as far as SLI goes yes the slots are close and the top card is gpnna be warmer for sure. a lot depends on air flow through your case and which cards your running really. If your running heat churning monsters then it becomes more prevalent e.g GTX480 SLI for example. I ran both Nvidia and ATI in multi GPU on the board but mine are water cooled so its not an issue then.
What cards you on????
I have this board in a Corsair 500r. Finished building it today - bar the CPU - and yes, the gpus are very tight together but it looks fine in the case, allows you to be neat in the space around it and it seems airy which makes it look like it can stay cooler.
When I get my CPU on Tuesday I'll report how my 2 5850s perform in crossfire temps wise.
Daru, I use the exact same case and 2 GTX 560 Ti TOP cards in SLI. It doesn't look odd at all. If I had placed the board in my full tower cosmos case maybe so but the 650d isn't actually that big.
Re: heat, you saw my post in the other thread on this forum. The 650d has magnificent airflow if you use the right fans. Never get above 21C case temps.
That sounds great. I was just a little concerned having never used mi-ATX before. And actually as you suggest a smaller board could have airflow benefits.
I've forgotten which fans you're using in your case, could you remind me?
I have 1150's and 1450. The 1450 I think is the best for output and low noise. I know they are expensive but they do last several builds. Mine are on 24/7 for years and not one has failed ever.
