Those bends are so precise and the radiator looks excellent fitted in the case. I must admit I never thought of a silver radiator until seeing this build log as It looks brilliant. I can't wait to see the finished system filled up![]()
Damn, still though it looks as if it's worth it for you as it looks stunning and you can't see any marks in the photoGot to be honest wouldn't go silver if i was you its a total pain in the butt and marks way to easy. We had to handle it with gloves so as not to mark it while fitting and even then we messed up.
Love the front cover, looks really sweet. Could you use the standard glass front and spacers to increase airflow or did you have to mod the fitting of the new front panel?
It looks awesome, but sounds a pita with the silver paint chipping so easy. The glass tubing is the mutts nuts though, so clean and precise...
***snip***
) I love the look of the tubing as it does the fluid justice as it's so clear and precission bent. In fact I think I may have to invest in some of the tubing myself when I do another build as it looks fantastic.
