Just be mindful that it is still an abrasive and not meant to be used as a cleaner, and you could cause deeper scratches trying to polish away marks and contamination like that.
I also used it on a textbook scratch and it worked wonders on that too.
The Turtle Wax Bug & Tar Remover only got 3 stars according to the Auto Express review so it’s not the best...
https://www.autoexpress.co.uk/product-group-tests/91350/best-bug-cleaners
Have you read any of the responses in this thread properly? Nobody is recommending the Turtle Wax product. Quite the opposite.![]()
I've had a bottle of tar remover for so long that the label came off years ago, I think it's autoglym. It's good stuff anyway, smells of petrol.
When I had an underseal done, the garage advised that a bit if petrol on a soft cloth is good at removing tar spots.
This is how not to clean a car. These should have been removed with a clay bar or mitt first
Wouldn’t come off with shampoo and a wash mitt believe me I tried.
Ah yes, the elite view point of a product/company that has a history of products far more established than more recent brands, knocked because of a "Turtle" as their brand image.
To be fair, not sure what I thought this thread would bring when I have to remind myself that the OcUK Motors Elite think "Autoglym Super Resin Polish" is actually a good polish. Tip: It's not. It's a filler. It literally says it in the name.
+1Regardless, how does that not make it a polish? It achieves largely the same results (albeit more temporarily than a cutting polish) - it makes the surface smooth and shiny. Just because it does it by a different mechanism doesn't make it not a polish, does it? I think it's good. I understand it's limitations, but I am limited to polishing by hand, and for that it's given me some of the best results.
Didn't take long for a member to turn up, as per![]()
I'm amazed that internet reviews support AG SRP as a good polish. It's almost like the internet is some sort of platform where joe public can quickly Google and review products based on having never ever heard of, or tried any other supreme product.![]()
Maybe you could enlighten us all with your superior knowledge and recommend these other supreme products.
I guess it's easier to just dismiss anyone who questions what he says by claiming they're part of some made up elite that only exists in his head. Means he can justify not elaborating further.
Which is a shame. I'd be genuinely interested if there's a product better than SRP for use by hand. I know there are better polishes in general, but I don't know of many which do as good a job by hand.
Any polish that actually cuts, as opposed to fills, obviously.Maybe you could enlighten us all with your superior knowledge and recommend these other supreme products.
