They are ok, the seats are crap, as they can be pulled apart by your hands with little effort, there is known reliability issues, not cheap to insure.
In red, I think they look quite purposeful. Other than I don't know because it's years since I drove one.
Go to www.mg-rover.org
And they are more than just a 25 with a bodykit. They do differ mechanically as well. They arent particularly cheap to insure as said. The only thing the K series engine really suffers from is HGF, and that is easily fixed if you maintain your car and keep an eye on coolant levels and oil condition.
And they are more than just a 25 with a bodykit..
[TW]Fox;14879861 said:It is the equivilent of a Rover 25 Sport and nothing more.
the HGF is an issue
