Midlag Crisis
Story behind the name,
my main current project is called Lean & Green or LAG for short, I was midway through & I had a hissy fit over something stupid which made my progress come to an emergency stop so had a little timeout to regain my sense, or at least some of it
could call the project anything since I never have it in writing on my projects, great story...
But I’m using this one to get me right back in motion to continue LAG straight after this.
It’s a small practical HTPC I'm making for my dad as a present, he's in Australia until the 8th of February & I aim to have this project completed well before then.
It holds an SFX PSU, mini-ITX mobo with support for regular height expansion card, Internal IR receiver, Internal 3.5" e-sata HDD dock which can be switched on/off & 1 3.5" HDD & 1 SSD & 1 140mm custom fan, 1 of the parts of the custom frame is the front panel too, got all the hardware covered already & this is my first rig without an optical drive.
Some concept shots.
The internal custom e-sata HDD dock has a sliding piece which 3 rods guide it so it goes forward/back nice & straight that has enough room to free the drive & then the HDD clips in/out of place with it's own little side panel for quick access.
After making it all printer ready.
The only material I had to buy was the 2mm panel & an acrylic tube with 16mm ID for the marble power button, everything else is scraps.
Cut into manageable pieces.
Drilled.
Cut & undressed after a nicely productive 10 hours, so that's the front, back, top, bottom, both sides, mobo tray & most of the HDD dock pieces & back IO piece but all the acyrlic bits need the adhesive before I can complete them.
Also cut some acrylic pieces but I can't find my tensol 12 adhesive so I'll have to order a new bottle & get it on Tuesday but this lets me complete everything else in the meantime.
This project should be a quickie.
Feels good to have done some modding after such a big timeout, I'll do more tomorrow.
Some concept shots.
Drilled.
you always have fantastic projects, looking forward to seeing this one come to fruition
