Didn't complete it over the weekend, ended up doing something unplanned.
Re made the fan spacers & the hoop piece, original spacers weren't long enough & the hoop wasn't wide enough or consistent width, needed 1mm more length, only really found this out when I actually stuck the fan to it, here is how I grind the sides of the spacers I already cut, drilled & tapped from 8mm round bar.
Assembled it without the hoop piece, not sure but I think I prefer it like this plus it's easier to assemble which is a nice bonus, I think it works for this one with the extra 9mm of layers but on LAG I think I'll keep the hoops in play, this fan frame design has 4 layers with the 4 spacers which hold the hoop in perfect position, this particular one has 7 & is trickier to install the hoop properly but works & looks fine without the hoop.
HDD dock vandal switch will be completed once the lacqodising is done, not got small spade crimps so had to make it permanent with solder.
Now then, here's something I've never had the guts to try before but there's no speedier way of learning than just throwing yourself at something, so snip away.
Dissected a sata cable & joined it back together again, under the first cover is 3 exposed wires resting separated by another shielding, under that shielding is 4 plastic coated wires of the same type, they are really fragile & break really easy, anyway I soldered the 4 double shielded ones together & coated in liquid electrical tape, the other 3 wires were too brittle & kept breaking needing me to expose more to re try so I soldered normal wire to them, applied a couple more coats of LET, let it dry & then coated in JB weld, cut about 150mm excess length off the cable, took a while with having to let the stuff dry, I'll leave the cable for a day before handling it, takes about a day for it to cure well & then it's like good hard plastic, it's done on a portion of the cable which won't have to bend too.
Then tested to make sure the mobo fits still because I didn't test it after the revised mobo tray, it's good still, about 2 or 3mm space between the mobo & fan lol, need to add a hole for passing power & data cable through.
Still another update before final shots, random sata cable mod took some time, gave virtually everything a good rubbing with the satinising pads though so just needs cleaning before applying the lacquer, has to be ultra clean for nicest results.
that would be a bit of mini disaster I'll definitely have to do colour tests before doing it to the project lol.
