Plenty of clearence for the thickest 120mm rads + fan, maybe even push pull too. Just about 110mm between the midwall edge and front of the case here:
Lol... Would love that! What would you do... Put them back to back with a fan sandwiched in between? Lol!
I am doing exactly this for a show rig ;D with TEENY fans:
Yes that would be awesome. Especially with acrylic in-between the fittings with pastel coolant.
For an extreme example look at the 9ine04 Project
Erm, where do the HDDs/SSDs go ?
Looking awesome! Can't wait to see how it turns out. Glad to see the positioning of the 24 pin on that board wont be an issue![]()
They go around the back, you screw them into a kind of false roof. If you watch the video I posted in the 2nd post you should be able to make it out. (its transparent which makes it hard to pic up in photos).
