Is the UE40MU6120 also ok to use as a monitor? Basically does it have the 4:4:4 chroma subsampling? I can't really tell what the difference between 6120 and 6400 is, besides the price.
Yes it does 4:4:4. Very similar panels. The 6400 has slightly better contrast and grey uniformity.Is the UE40MU6120 also ok to use as a monitor? Basically does it have the 4:4:4 chroma subsampling? I can't really tell what the difference between 6120 and 6400 is, besides the price.
Im interested in this also. Plus does anyone have experience of how 1440 looks on the 6400? 4k would be sweet but i doubt my 1070 would drive that with all eye candy on at 60fps+. I like 1440 in that regard as i can whack settings to full and mostly get 60fps.
TVs usually do a great job displaying non-native resolutions.
PC mode turns off unnecessary post processing. Monitors also have scalers built in, TVs usually have better ones.Any idea if this applies to TVs in PC mode though? I thought that in order to cut out input lag it had to run without the fancy scaling stuff?
1440p looks fine to me.
A bit 'soft' sure but it's worth it to keep the fps up.
A lot of games run fine in 4k though with some tweaks.
I bought one based on this thread but ended up returning it. If you looked at it on it;s own it looked sharp but compared my U3415W and S2417DG Monitors it looked slightly "off". I found it giving me a headache even after short periods of web browsing. Otherwise a nice TV. I definitely had it setup correctly with 4:4:4 etc
I can confirm that. Tried Killing Floor 2(Unreal 3 Engine) in 1440p and scaling works really well. Still helluva playable.
That'll be the PWM causing headaches.
The built-in image processing seems to soften images resulting in lost detail. On the few TVs I've tried recently 1080p bluray content looks almost like SD content when compared to a PC monitor side by side.
