@ColinD how do I test for PWM?Thanks for the review. I was wondering if it used PWM?
I've had a search around and other samsungs have, as have many, but nothing concrete on this.
Does anyone know, or any owners able to quickly test it, this would be really appreciated.
TY.
Absolutely no different IMO, I've just measured mine to confirm and compared to the Philips BDM4065 UC as measured by TFT central: http://www.tftcentral.co.uk/reviews/philips_bdm4065uc.htm)
Philips BDM4065UC:
Manufacturers Quoted Consumption = 77.6W
Measured at manufacturers settings = 81W
Measured at Calibrated Brightness (120 Lumens) = 45W
My figures:
Samsung 40KU6400 Quoted = 62W
Measured at manufacturers settings = 66.5W
Measured at Calibrated Brightness (120 Lumens) = 47.1W
No probs:
PC Setup
Input set to 'PC' (Highlight the HDMI 'source' icon and press up, then edit, then select PC)
Picture Mode - Standard
Special Picture Mode - This says 'SPORTS' but is actually turned off when you drill down in that menu.
Expert Picture Settings:
Backlight - 8
Brightness - 49
Contrast - 99
Sharpness - 50
(Everything is now greyed out between this and the next option)
HDMI UHD Colour -> HDMI the PC is connected to is 'ON'
(more greyed out stuff)
Colour Tone - Warm 2
White Balance -> 2 Point ->Red Gain 14 / G Gain -3 (all others 0)
Gamma - 0
When you select 'PC' as the input type a lot of stuff is greyed out so there isn't any other adjustments to make.
This is for 2.2 Gamma, 120 Lumens, D65 white point which is the normal monitor calibration target as per TFT Central etc.
Where is the cheapest place currently selling this TV? Can't seem to find this model anywhere for the prices you guys have claimed to purchase it for.
Also I'm seeing slightly different models being listed, but they seem identical feature wise. Which models should I be looking at?
There is a great deal of similarity in terms of features.
The main difference is in the Crystal Colour (I think this is part processing, part pixel drive circuitry), this gives it a slightly wider colour gamut (86% vs 83% DCI-P3) and as stated above, slightly increase PQI (1500 vs 1300)..
It also has slimmer bezels if that counts for anything.
Hi @ColinD,@Pyr0m@nI@]{ thanks for asking and I hope this helps.
The way I've been doing it is, with my mobile on camera mode. At full brightness you won't see anything of note, there is no on_off pulses of note. Then as you lower the brightness, keep looking through the camera view. If you get to <10% and no change then we're good, the PWM side of it uses a high enough frequency not to be an issue.
If not, so it begins to change, you may see a set of bands scrolling as the brightness lowers. Then the PWM isn't using a great frequency. Most of the thinkpad laptop line are in this boat sadly.
So what?
This pulsing can be detected by some and cause headaches/eyestrain etc. Only by like 10% or so of the users in a report I read... I was fighting with headache and tiredness for 3 years before discovering this 'feature'. Swapped monitor from a nice dell 27 1440p and voila day #2 much better and still better now. Not 100% but a darn site better, any screen use over looking at mountains hurts my eyes.
I'm tempted to keep an eye out for this tv as 2017 begins.
Pyr0m@nI@]{;30338268 said:Hi @ColinD,
Unfortunately I'm returning the KU6400 to JL as I've had a couple of instances of blue lines/corruption which could happen randomly when watching or when the TV/CPU was busy.. doing firmware updates for example.
Unfortunately I'm returning the KU6400 to JL as I've had a couple of instances of blue lines/corruption which could happen randomly when watching or when the TV/CPU was busy - doing firmware updates for example.
I did test with my phone (s7 edge) before packing it away and only saw flicker on the camera with the backlight at 0 or 1.
Today I picked up a 43" KS7500U instead.
I had some blue lines appearing 2 or 3 times for a few seconds each time at the bottom of the screen when watching a film the other day (powered by the PC so the TV CPU shouldn't be doing too much).
I've not seen it since, but I hope it's not sign of things to come.
