- 18 Dec 2008
Had this TV for just shy of 2 months now and I really like it. It's been mainly used for the PC and only occasional TV watching.
I have also seen the flickering blue lines near the bottom of the screen for a second or two. It usually happens not too long after turning on but will then go for hours without happening again. I'm not too worried about it at this stage but if it becomes more frequent, I will consider getting a replacement.
Anyway, I'm picking up a PS4 Pro tomorrow and so will likely be switching between that and the PC quite regularly. As the TV only has 1 (of 3 total) HDMI port that will allow selection of the 'HDMI UHD Colour' setting, ideally, I need a way to run and switch between both machines via the one HDMI port, preferably - though not essential - remotely, but definitely without losing any image quality.
Can I just be looking at any regular male to 2x female HDMI splitter or do I need to be looking at something more elaborate, so as not to have to compromise on image quality?
I decided to take the plunge and got myself a 6400 over the New Year.
I share the HDMI#1 input for my Pc and XB1s
I went for the Ligawo 3090063 HDR HDMI switch 3x1 https://www.amazon.co.uk/LIGAWO-3090063-HDMI-Switch-Black/dp/B01KXCO65E and some KabelDirekt HDMI 2.0a/b highspeed cables.
I'm very pleased with the results and so far everything is working as it should.
FH3 in HDR looks stunning on the XB1s (better than it ever did on my IPS Pc monitor)
Thanks Demon - if I hadn't stumbled across your excellent review I would never have gone down this route.
