"Looks a bit Heath Robinson" may be my new favourite phrase ever.
This is looking amazing.
Oh its Heath Robinson in certain areas, your right there!
Structurally its very rigid and theres no movement, flexing in the case whatsoever, but a lot of the work I did could have been done differently/ better but I'm limited in the tools I had available, a jigsaw, files and a drill basically.
I personally think it looks a little "bitty" with some parts (the floor mounted fan 'frinstance) looking like they've just been stuck in position and don't look "right" although they do work as intended.
Am I happy with it? With the internals, aesthetically no! but from a performance angle, yes, it does what I wanted it do from the outset, give great cooling and enough space to fit up to date components, I just think it looks a bit, dare I say it, Meh!
So, the above is the reason I've just my hands on a "pair" of black atcs 201 SXT cases which have suffered a bit over the years but hopefully nothing major that can't be corrected. My intention is to do another case mod, but with a few differences to allow for greater flexibility. Things like mounting the psu at the bottom, use a 92mm fan exhausting instead of a 120mm (as said in my earlier post, it makes no difference to temps) and keep the 5.25" bays clear for a double bay mounted water cooling pump/res assembly.
Also, get tooled up a bit more to improve build quality.
