Update 21/04/09
Done a bit more to the build.
Corsair fan cooler was very boring stock so i took out the 60mm fans and painted the blades white to go with the rest of my fans.
I got some 60mm chrome wire grills and painted them white and these will be going on the memory cooler when they are dry.
Also painted the rear case catches black as silver looked odd,the silver lian li case screws got a nice coat of paint to.
Got a new DVD writer and took the panels off and sprayed them satin black to match the inside.
Primer
Finished
Heatkiller backplate painted white.
Now how to take apart a yate loon 140mm.
On the back of the fan there is a sticker peel this off,you will find a rubber gromet just pop it out with your fingers.
Next is a small plastic circlip,use a small bladed screwdriver to remove and be very carefull as they can fly off.
Plastic clip removed,there is a small rubber washer and a metal washer leave them on the fan.
Then its just a case of pulling the fanblade away from the main body.
6 140mm rad fans with grey primer.
Now the 6 fans painted white,the one at the bottom is for the front lower its a 120mm x 20 yate loon as ive had a idea about mounting and cooling the waterpump in one go.
Will cutting the mesh up and sorting out my cables next.
Primer
Finished
